enable snmp trap l3vpn
enable snmp trap l3vpn {vr_name}
Description
This command enables Layer 3 VPN MIB notification traps for the child VPN VRFs of the specified VR.
Syntax Description
vr_name Specifies the name of the parent VR where this RFC 4382 scalar is applied. If vr_name is not provided, then this command is applied to the VR in the current context.
Default
Disabled.
Usage Guidelines
This command enables generation of the following Layer 3 VPN SNMP traps:
  • mplsL3VpnVrfUp—Sent when the first IP VLAN becomes active and the administrative state is enabled.
  • mplsL3VpnVrfDown—Sent when the last active IP VLAN becomes inactive, or the administrative state is disabled.
The following example enables SNMP traps for Layer 3 VPNs on the default VR:
enable snmp traps l3vpn vr vr-default
This command was first available in ExtremeXOS 15.3.
Platform Availability
